Vpn100 sys blinking red and green
Hi @Luc999,
The SYS LED should be Green Blinking or RED. It seems a hardware issue if SYS LED is blinking red. You can contact your reseller for RMA. Here is the LED status for your reference.
Blinking red light on a LED that should be only green and not blinking: could be either a hardware or a firmware problem.
Example of hardware issue: Fan failure or impending fail.
Example of firmware or config issue: incorrect configuration command or firmware error.
You will be asked by one of the Zyxel team members to send a console log in private message. You could also read your console log to see if you notice what is wrong.
Hi @Luc999,
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
