Nebula support for RADsec
Please add radius support for RADsec to Nebula managed AP's.
Hi @n_j
To better understand your usage and the need for this feature, could you please provide more details about your current network setup and how you envision utilizing RADsec with Nebula managed APs? Understanding your specific requirements and use cases will help us evaluate the feasibility and prioritize the implementation of this feature.
Kay
The goal is to use WPA Enterprise authentication for wifi, via a secure TCP/TLC to a SaaS radius service. To eliminate the need for internal PKI/radius infrastructure (and VPN tunnels to access that) for remote "intenet only" sites. E.g. to authenticate AzureAD joined computers.
So both APs and Nebula need to support this configuration.
Hi @n_j,
Thanks for your input! We'll be monitoring the votes and comments as part of our evaluation process.
If anyone likes this idea, please show your support by leaving a comment or voting for it.
Zyxel Melen0 -
Hi @Zyxel_Kay
Apologies, I overstated the significance of RADSEC by saying that it makes deployments easier.
We would like to use RADSEC for a more secure 802.11x implementation on our switches. This would also be a lot better for others that want to use RADSEC authentication for their wireless infrastructure too.
Hi @zeal_x
Thanks for your response. We would appreciate it if you could share more information with us. There are two additional things we would like to clarify:
- Could you please share the switches model that you are using?
- If we implement 802.1x on the Nebula Cloud Authentication Server (NCAS), will it fulfill your requirements? NCAS uses TCP/TLS, but currently, we only support MAC authentication with NCAS.
Kay
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 300 Service & License
- 483 News and Release
