Zyxel Flex 200 - availablity
mm_bret
mm_bret Posts: 63  Ally Member
Wondering when the subject model is going to be available.
Amazon is out of stock. ZyxelGuard isn't on their game. Non on your webstore.
Regards,
Bret
  • mm_bret
    Not the 200h.
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 352  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @mm_bret,
    Greetings.
    We have USG FLEX 200 with bundle license and non-bundle; which device would you like?
    Please let me know which country/area you are.
    I can check for you.
    Thanks.
    Ivan
  • mm_bret
    Ivan,
    Non bundle, hardware only. USA
    We need for new use and spares if units fail.
    New 200h doesn't support Ikev1 vpn, we have many older ikev1 vpn's and need the older
    protocol support, so we need Flex 200 devices.
    Thank you for the help,
    Bret
  • Zyxel_Ivan
    Dear @mm_bret,
    I've checked with the team.
    Regrettably, the non-bundled USG FLEX 200 is currently unavailable due to stock shortages. Given the anticipated delay in restocking the non-bundled device, we recommend considering the bundled device as an alternative.
    Please feel free to have any feedback.
    Thanks.
    Ivan
  • mm_bret
    Ivan,
    That won't work. We don't need bundled devices.
    I will search for an alternative device.
    Regards
  • mm_bret
    For now we will use USG 60 devices.
  • mm_bret
    When will Flex 200 be back in stock?
  • Zyxel_Ivan
    Dear @mm_bret,
    After checking with the team, there's no lead time so far.
    Thanks.
    Ivan
Service & License Help Center
