How to configure Voice VLAN on Zyxel Switch 1920
alankevinr
alankevinr Posts: 5
edited February 2024 in Switch
I have set the VLAN Voice VLan 30 Ports 5,6,7,8 are tagged and is untagged for data traffic
I noticed I have to set up OUI Mask and address but its failure on all permutations
MAC Address 9C:75:14:07:CF:76
Vendor Wildix srl
Block Range 9C:75:14:00:00:00 - 9C:75:14:FF:FF:FF
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,220 image  Zyxel Employee
    Hi @alankevinr,
    To better assist you, may I know if your topology is the first one or the second one?
    The first one:
    Untitled Image
    The second one:
    Untitled Image
    Zyxel Melen
  • Hi Melen, Neither
    I have three VLANs, default VLAN 1 for Network switches and AP's
    VLAN10 Corporate network, VLAN 20 Guest and VLAN 30 for phones.
    172.16.225.0/24 VLAN 1
    10.75.1.0/24 VLAN 10
    10.72.1.0/24 VLAN 20
    10.73.1.0/24 VLAN 30
    I have 8 phones on ports 2 4 6 8 10 12 14 16
    When connecting on the wireless network using Unifi AP's, I can connect with the right DHCP addresses from the right VLAN.
    The phone vlan 30 is tagged, i have tried as well setting PVID with VLAN 30 and untagged as VLAN 10.
    This is due to using the second port of of the phone on VLAN 10 corporate network the above works without setting the PVID on other manufacturing switches, but not on Zyxel
    Hopefully this a clear set up.
    Kindest REgards
    Alan
  • Zyxel_Melen
    Hi @alankevinr,
    Thanks for your feedback.
    It seems like your Laptop/PC connects to the IP Phone's PC port, and the IP Phone's Internet port connects to our switch. Please reference the FAQs below and test:
    V4.70 firmware:
    V4.80 firmware:
    If there still have problem, could you share the switch and the IP Phone's configuration with me to check? Please send the configurations by the private message.
    Zyxel Melen
  • Hi Melen, thank you.
    This is now working but as you say untagging the Data Vlan and voice VLAN 20. Then setting PVID to the Data VLAN configuring the Voice VLAN Setup
    Specify the OUI addresses. OUI are the first 3 bytes of a MAC address that represents the vendor. Through specifying the IP phone MAC address, the switch can identify voice traffic accordingly. Zyxel switch supports up to 6 vendor OUIs.
    So with Wildix Phones I used OUI Mask: ff:ff:ff:00:00:00 & OUI Address: 9c:75:14:00:00:00
    All is now working.
    But did you know after you do all the above have your tried configuring and untagging a Voice VLAN port that you may have missed or later down the line they give you another phone to configure. it errors stating VLAN is already in use.
    You need to then switch off Voice VLan set up, configure your port as above then re-enable VOICE VLAN setup then that ports starts working
    try it let me know your findings .
    Kindest Regards
    Alan
  • Zyxel_Melen
    Hi @alankevinr,
    Thanks for your feedback. I have checked this problem occurs on V4.80. I'm checking this problem with our team. I will keep you posted once I have further information.
    Zyxel Melen
  • Zyxel_Melen
    Hi @alankevinr,
    After checking, we confirm this issue is a bug. We will fix it in the future firmware release. If you need a date code firmware, please let me know. I will send the date code firmware to you via a private message.
    Zyxel Melen
  • Hi Melen thank you for confirming how to apply vlan tagging for voice. I am glad to have helped in making these switches better for future firmware releases.
    Take care kindest regards
    Alan
