USG Flex 700 AP using a LAG (Link Aggregate)
jef
jef Posts: 90  Ally Member
edited February 2024 in Security
"Forwarding Mode" Tunnel
The "Interface" (lag1) is not in the drop down selection?
I created a LAG "lag1" from ge8 and ge9;
Configured lag1 as internal.
So, what is the trick to using a lag and having a wifi forwarding tunnel ?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,348  Guru Member
    Hello @jef
    Could you please provide a GUI screenshot and describe your topology and purpose? This would make it easier for us to understand your current situation. Thank you.
  • jef
    The purpose is to link (LAG) the POE switch with the USG.
    This will increase the bandwidth for all the connected user on the switch.
    48 gig ports connect by 1 gig seems pretty silly, wouldn't you agree.
    Ethernet LAG.. picture
    Object AP Profile.. picture.
  • jef
    PeterUK Posts: 4,039  Guru Member
    Guess you can't but in any case the Zyxel LAG on Flex 700 is limited to 1Gb even with two or more ports if you check your LAG settings you find you can only set to egress and ingress bandwidth to 1048576 Kbps
    With some hope the FLEX H can do it better in next firmware down the line
  • jef
    "LAG are limited to 1Gb" that is horrible.
    Thank you for pointing that out, I appreciate it.
    I could not be more disappointed.
