USG Flex 700 AP using a LAG (Link Aggregate)
Hello @jef
Could you please provide a GUI screenshot and describe your topology and purpose? This would make it easier for us to understand your current situation. Thank you.
The purpose is to link (LAG) the POE switch with the USG.
This will increase the bandwidth for all the connected user on the switch.
48 gig ports connect by 1 gig seems pretty silly, wouldn't you agree.
Ethernet LAG.. picture
Object AP Profile.. picture.0 -
Guess you can't but in any case the Zyxel LAG on Flex 700 is limited to 1Gb even with two or more ports if you check your LAG settings you find you can only set to egress and ingress bandwidth to 1048576 Kbps
With some hope the FLEX H can do it better in next firmware down the line
"LAG are limited to 1Gb" that is horrible.
Thank you for pointing that out, I appreciate it.
I could not be more disappointed.0
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 305 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
