I want to know the sistem password for Zyxel router P_660W-Tx series
Metab
Have you tried searching the internet (Google or Bing search engines) to find pages or manuals for your router? I do not know the exact correct answer, but some can be found on this page:
(Google search: https://www.google.com/search?q=zyxel+p-660w-tx+password )
More than one suggestion says that the information is found on a label on the bottom of router.
Agree. I search on Bing and there is a good result: https://www.manualslib.com/manual/868428/Zyxel-smash karts-Communications-P-660w-Tx.html
The default login credentials for the Zyxel P-660W-Tx v2 ADSL Router are as follows:
IP Address: 192.168.1.1
Password: 12341
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
