NWA50AX as an Extender only
Hi @Fuisdale2
Currently, there isn't a router that's compatible with the NWA50AX's Smart Mesh technology. However, we're excited to announce that a new router supporting Smart Mesh is coming, expected to launch in Q2 of 2024.
Stay tuned for updates on this upcoming product :)
Nami
Hello @Fuisdale2
Could you share the model of your Zyxel Broadband router? Also, are you looking to connect the NWA50AX to it wirelessly using Mesh functionality?
Nami
hello,
my Zyxel router module number DX3301-T0
if possible I would like to connect it via Mesh.
Currently router is managed on MPro mesh app and access point is on Nebula
Hi @Fuisdale2
The DX3301-T0 uses MPro Mesh technology, while the NWA50AX operates with Smart Mesh, which unfortunately aren't compatible. This means setting up a Mesh network between these two specific devices isn't recommended.
To ensure seamless mesh compatibility with the NWA50AX, you might want to look into other models within our Access Point series.
Nami
Do Zyxel do a Smart Mesh WIFI router if I decide to replace my DX3301-T0 .
Hi @Fuisdale2
Nami
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
