Wireless Bridge
I need to configure NWA55AXE to connect as repeater with wifi bridge to router WiFi DX3301-T1 (internet access) and a local switch with PC and other devices, but I am not able to connect to any WiFi device and his SSID is not visible to wifi scanner.
May please help me?
Thanks,
Frediano
Best Answers
Hi @Frediano ,
We would like to inform you that the NWX55AXE access point and the DX3301-T1 router employ distinct mesh solutions, making them incompatible for direct mesh connection. Consequently, it is not feasible to configure the NWX55AXE as a repeater for the DX3301-T1.
Should you wish to establish a mesh network utilizing the NWA55AXE, it is essential to use a Zyxel access point as the root in your setup.Zyxel_Judy
Hi @Frediano ,
In your setup, one of the NWA55AXE APs, designated as the root AP, needs to be connected to the DX3301-T1 router via an Ethernet cable (wired connection). The other NWA55AXE, serving as the repeater AP, can then establish a connection to the root AP using MESH technology (wireless connection).
For instructions on setting up a MESH between APs in Nebula, please consult the following FAQ. [Nebula] How to extend wireless coverage by configure smart mesh? — Zyxel Community
Additionally, seamless client roaming between the DX3301-T1 router and NWA55AXE APs is possible when devices share the same SSID (Wi-Fi name) and security settings, provided there is signal overlap between them.
Zyxel_Judy
Hi @Frediano ,
I have both MESH enabled but always no connection, and after Nebula registration I am not able to find how to set Repeater mode instead of AP.
This is what I have to do:
At moment I am working only with a room.
If it helps, consider that I also have a pair of NWA50AXs
Many Thanks,
Frediano
Hi @Frediano ,
Zyxel_Judy
Thanks for reply
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 463 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 439 News and Release
- 4.3K FAQ
- 91 Security Highlight
