How to properly remove NWA50AX from Nebula NCC
I installed the AP using the NCC Nebula method. After noticing, that Nebula is not free of charge, I removed the Device in my Nebula APP, reset the device and re-configured it locally using the Configuration Wizard within the Web Browser. However, when the AP reboots, the Dashboard still shows the AP as registered in the NCC. I still get the NCC layout of the Dashboard. But I want my device be managed purely locally, without any impact from the NCC. What do I miss?
Hi @slowfood27 ,
The Nebula Mobile App is designed for convenience, allowing you to remove devices from a specific site without removing them from the organization altogether. This means your NWA50AX remains accessible within Nebula.
To fully remove the NWA50AX from Nebula, it is necessary to use the Nebula portal. For detailed instructions on this process, please consult the relevant FAQ section.
How to Remove Your Device from Nebula and Administer It Locally — Zyxel Community
It's important to note that Nebula offers a comprehensive, license-free feature set that includes a wide range of management capabilities at no cost. Subscriptions are only required if you wish to access additional advanced functionalities and enhanced management features.
Zyxel_Judy
i have the free version of Nebula and manage router, switch and six ap. For my needs the free version cover all my needs.
thanks for your reply. Gut it dies Not auswerten my question :-)
Hi @slowfood27 ,
Zyxel_Judy
- 441 Beta Program
- 292 Service & License
