after ssl connect with secuextender, client cannot see lan1
Firmware received, and all problems solved. Thanks @Zyxel_Charlie for great support!AndersO said:USG110 - Firmware 4.32 - Same issue. Windows 10, TAP driver (version 9) stays on default IP, and not range of VPN.
Hi @Zyxel_Charlie,
pleae can you send me also the new firmware - no ip with USG110 4.32 (AAAA.0).
Thanks0 -
Hi.We have same problem on a USG20W-VPN FW:4.32(ABAR.0), could you send me the firmware.4.0.2.0 works fine..
@Puzzle
Regarding to this case,
the solution will be included in firmware 4.33 which will release around the end of Jan.
However, I will private message firmware to you. Please has a check.
Charlie0 -
Hi, please can you send me also the new firmware, if solving problem :
https://businessforum.zyxel.com/discussion/2071/secuextender-4-0-3-0-for-windows-failed-to-access-zywalls-lan
Very Thanks Vaclav
Hi, I'm having exactly the same issue with 4.0.3.0 firmware on a USG110, could you please send me the updated firmware?0
Hi,We have the same problem on a USG110 FW:4.32 could you send me the firmware update please?Thanks
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
