Enable Qos on my am3100?
Can not find the option on the router…
Hello @Cantona1983
Welcome to the forum.
Do you have an AM3100-B0 device?
- see https://www.zyxel.com/service-provider/global/en/products/fiber-oltsonts/active-fiber/hgus/am3100-b0
If so, are you using it in Bridge mode or Router mode please? and what firmware are you running?
Looking at the user guide available at then if your device can do QoS, then you need to look for the Network → QoS → General tab (see below image) and enable QoS with the sliding control.
Kind regards,
Tony
Yes i have a AM3100-B0 device👍 Firmware Version V5.17(ABNY.9)E0
I run the default. So no bridge mode. Im not that tecnical when it comes to this 😂🙈
only options i have:
Hi @Cantona1983
Thank you for your replies.
I think that the E0 on your firmware version means that it is a customised firmware version with options removed.
I think that this is why you cannot see the options for QoS.
If you connected another additional router to your AM3100-B0 on the LAN side of it, then that additional router could have QoS settings for you to use.
Kind regards Tony
The approach in the application picture below might work for you @Cantona1983
Kind regards Tony
ok. Really appreciate your help 😊👍Can i ask my fiber company to update my firmwire instead? If i use another router. I will lose a lot of speed? I only have a wifi router provided by the same company 🙈😔
Hi @Cantona1983
You're welcome 😃
You could ask, but since Zyxel have declared AM3100-B0 end of life then it might not be possible.
I do not think that you will lose a lot of speed with an add-on router if any, but you might have some more latency delay.
Kind regards Tony
thats what i am afraid of 🙈😔 latency are bad here now! Maybe they can send my a new router to replace the old am3100… thanks again 😊
QoS will not save you if your idle and ping is bad
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
