Enable Qos on my am3100?
«1
  • Can not find the option on the router…
  • tonygibbs16
    tonygibbs16 Posts: 977 image  Guru Member
    Hello @Cantona1983
    Welcome to the forum.
    Do you have an AM3100-B0 device?
    - see https://www.zyxel.com/service-provider/global/en/products/fiber-oltsonts/active-fiber/hgus/am3100-b0
    If so, are you using it in Bridge mode or Router mode please? and what firmware are you running?
    Looking at the user guide available at https://spdl.zyxel.com/AM3100-B0/user_guide/AM3100-B0_V1.pdf then if your device can do QoS, then you need to look for the Network → QoS → General tab (see below image) and enable QoS with the sliding control.
    Kind regards,
    Tony
  • Yes i have a AM3100-B0 device👍 Firmware Version V5.17(ABNY.9)E0
    I run the default. So no bridge mode. Im not that tecnical when it comes to this 😂🙈
  • only options i have:
  • tonygibbs16
    edited February 2024
    Hi @Cantona1983
    Thank you for your replies.
    I think that the E0 on your firmware version means that it is a customised firmware version with options removed.
    I think that this is why you cannot see the options for QoS.
    If you connected another additional router to your AM3100-B0 on the LAN side of it, then that additional router could have QoS settings for you to use.
    Kind regards Tony
  • tonygibbs16
    The approach in the application picture below might work for you @Cantona1983
    Kind regards Tony
  • ok. Really appreciate your help 😊👍Can i ask my fiber company to update my firmwire instead? If i use another router. I will lose a lot of speed? I only have a wifi router provided by the same company 🙈😔
  • tonygibbs16
    Hi @Cantona1983
    You're welcome 😃
    You could ask, but since Zyxel have declared AM3100-B0 end of life then it might not be possible.
    I do not think that you will lose a lot of speed with an add-on router if any, but you might have some more latency delay.
    Kind regards Tony
  • thats what i am afraid of 🙈😔 latency are bad here now! Maybe they can send my a new router to replace the old am3100… thanks again 😊
    PeterUK Posts: 4,147 image  Guru Member
    QoS will not save you if your idle and ping is bad
