ugly bug in IPV6 config part of latest XMG1915-10E switch firmware?
2 new XMG1915-10E, both with latest V4.80(ACGO.1) firmware, configured standalone:
(IP, DNS et al via DHCP and DHCPV6 active on VLAN 1, just one VLAN with ID 1)
on both, almost always when I try to ask for details of the IPV6 status of vlan 1
(System - IPV6 - IPV6 Status - click on the only VLAN with index 1)
the switch crashes and takes several minutes to come up and be usable again:
NO system: System cold start
IN system: Image 2 F/W version V4.80(ACGO.1) | 08/31/2023 boot up
AL system: System has reset without management command
otherwise switch works fine with IPV6
PS: one more info about the config:
IPV6 config data (DNS, IA_PD, and IA_NA) comes from fritzbox (DHCP rapid commit set),
switches are set as DHCP6 clients with IA_NA, rapid commit, DNS and Domains enabled
Anybody else with this ugly problem?
The issue you're experiencing will be addressed in the upcoming firmware update. Please stay tuned for further announcements regarding enhancements and fixes.
Zyxel_Judy
Hi there,
To assist you more effectively, could you please follow the FAQ to download the tech-support and provide us here or via the private message (clicking to my account > Message)
Zyxel_Judy
Attached please find the Tech-Support data you asked for…
Hi @cbeckstein,
Thanks for the tech support. I have downloaded it and will remove it from the public.
Zyxel Melen1 -
Hi @cbeckstein
We have successfully reproduced the issue and are actively working to address it. We will provide you with updates as soon as possible.
Zyxel_Judy
Zyxel_Judy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
