Enable Qos on my am3100?
yes, I'm aware of that, but it might help a bit.
what do you recommend then?0 -
Hi @Cantona1983
My suggestion is probably to talk to your Internet Service Provider (ISP) as your next step.
To ask them for a lower latency service if possible, and whether QoS is enabled on the AM3100-B0 or not.
Kind regards,
Tony
i called them this morning. They couldn't do ant adjustments inside my router because they didn't have access and permission to do so … asked for a newer router but they could not do that either. Good costumer service… 😡🙈
So i am stuck with a router i can’t do much tweeking to 😔
- 238 Nebula Ideas
- 6.8K Security
- 754 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
