How to do Vlan tagging/grouping for EMG6726-B10A
I’m trying to make different vlans and tag them but my Web Configuration doesn’t have the option under “Network settings” so I assume it’s my firmware version it’s currently “V5.13(ABNP.6)C1_20220317”. I read the user guide pdf to update the firmware but it says “Click Maintenance > Firmware Upgrade” but there isn’t even a maintenance tab to click on in my navigation panel. I only have Connection Status, Network Settings, Security, and System Monitor. What should I do to get Vlan tagging?
Hello @Justrynalearnfr
Welcome to the forum.
From my reading of chapter 14 of the user guide linked from https://www.zyxel.com/service-provider/na/en/products/ethernet-cpe/ethernet-gateways/emg6726-b10a you can use the VLAN Group feature to create VLANs tagged with IEEE 802.1q tags in the Ethernet frames.
VLAN Group is a tab under Network Settings.
But maybe you don't have this option under Network Settings…due to reduced options in the firmware.
Can your ISP help?
Kind regards,
Tony
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
