Can i somehow convert my config file from the usg 110 to the new flex 100?
someguywithproblems
in Security
Hello guys
i recently switched from my old usg 110 to the new flex 100. the problem is that my config files dont work because i got an "other modells configuration file" so it wont work… any potentional fixes to that ?
i have heard that you could potentionally convert it to the flex 100
Hello @someguywithproblems
Could you provide your USG110 config file to us by private message? We will send a private message to you later. Please check your inbox, thanks.
@someguywithproblems I suggest you to don't use converted config.
Here it's detailed how and why I come to this conclusion.
- 441 Beta Program
- 530 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
