modem and Zytel switch seem to have same address
Hi @PRL ,
- If DHCP is not activating on your modem, there are two primary methods to resolve the problem:
Method 1: Using ZON Utility to configure IP settings
- Download and install the Zyxel ZON Utility. Follow the instructions provided there to assign a static IP address to your SW. How to use ZON to configure Zyxel device basic setting. — Zyxel Community
- Once a static IP has been set, enter the switch's IP address into your SW web browser.
Method 2: Isolates the switch
- Disconnect the switch from the modem to isolates the switch.
- Consult the relevant FAQ section for guidance on how to assign a static IP address to your PC, ensuring it is in the same subnet as your switch's IP. Setting a static IP address for your PC to access your AP — Zyxel Community
- After setting a static IP on your PC, and RESET the switch, use your web browser to navigate to the switch's default IP address (e.g., 192.168.1.1) to access the login screen.
2. If DHCP is functioning correctly with your modem, you should:
- Log into your modem's GUI.
- Check the DHCP table to find out the IP address assigned to your switch.
- Enter this IP address into your web browser to reach the switch's login screen.
Zyxel_Judy
Hi @PRL ,
Zyxel_Judy
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
