[Hotfix] Throughput Issue Identified with Specific Network Cards on NWA50AX,NWA55AXE,NWA90AX
Hotfix For:
We have recently been made aware of a throughput issue affecting our AP product. This issue specifically impacts the data reception (receive direction) performance and has been reported when using the following network cards:
- Intel BE200
- Intel AX210
- Intel 211
- Intel AX 201/411
- MTK MT7992
It's important to note that the transmit direction is not affected, and this problem seems to be isolated to these particular models of network cards.
For users encountering lower throughput on the receive direction with these network cards, we have made a date code available for download. This update is aimed at addressing the compatibility and performance concerns.
If you are currently not experiencing any issues, we recommend continuing with your existing setup without any changes.
Affected Models:
- NWA50AX
- NWA90AX
- NWA55AXE
Upgrade Steps:
Before you start to perform the date firmware upgrade, please go to Nebula web site, navigate to Nebula > Site-wide > Configure > Firmware management as Ignore upgrade firstly to prevent auto upgrade override the provided firmware.
Upgrade via ZON tool:
- Download and progress the installation of ZON tool.
2. Connect your laptop to the same network with your AP, then open ZON.exe.
3. Select the “settings” icon on the right side of the bar
And choose the network interface card which you’re using connect to your network.
4. Click the “Clear and rescan” button
Wait until the scan process is complete, you’ll be able to see your AP is listed in the table.
*Please ensure the laptop running ZON tool is connect to the same network with correct network interface card selected in settings to scan (Step 3.)
5. Select the AP which plan to upgrade the provided firmware, then click the “Firmware Upgrade” icon.
6. Select the “Local upgrade” option and click “Browse…” to upload the provided firmware. (.bin file), and fill in the password, then press “OK” button to proceed the upgrade.
*Note: If your device is being managed on Nebula, please go to Nebula web site, navigate to Nebula > Configure > Site setting > Device configuration to check your password
Additional upgrade method:
Local GUI (*Standalone mode only)
Hotfix Solution:
NWA50AX
NWA55AXE
NWA90AX
Noted: This version is based on 6.29P3 instead of 6.29P4, with the only difference being the optimization of WIZZARD, which does not affect functionality.
If you observed or met any other unexpected issues, please contact us.
We apologize for any inconvenience this has caused.
I think this issue is not just related to these APs and Clients. I have NWA210s and I experience the same on them and also my Pixel 7.
Hi @jpblanch75
The issue you're experiencing with the NWA210AX access point is not related, as the chipset design on the NWA210AX differs from the SB model APs.
For more discussion about your concern, please refer to this thread:
Kay
Hi, why do I have to disable cloud firmware updates?
Shouldn't this fix be included in the official firmware?
Hi @quodata
As of now, the hotfix hasn't been integrated into the Nebula cloud's latest official firmware. If you don't disable the auto firmware upgrade on Nebula, the system will automatically override any manual firmware upgrades with the hotfix.
The hotfix is specifically targeted at resolving throughput issues with certain network card models:
Intel BE200
Intel AX210
Intel 211
Intel AX 201/411
MTK MT7992
If you're using one of these, consider upgrading to the hotfix; otherwise, no changes are necessary for unaffected users.
Rest assured, the hotfix will be included in the upcoming official firmware upgrade. Stay tuned for updates on .
Kay
- 441 Beta Program
- 293 Service & License
