[NEBULA] Nebula remote IP address?
Chacha
Chacha Posts: 11 image  Freshman Member
edited April 2021 in Nebula
I want to lock down the nebula NAP access , i.e open the access in the firewall for NAP102.
From the support I can see the following ports are required : 123 UDP / 443 TCP / 6667 TCP
But what is the IP address to allow access from? Is inbound access required?
Your quick response will be the most welcome.
  • arthurdent
    arthurdent Posts: 3 image  Freshman Member
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - WLAN
    Hey, it has been a while, but i need to know if the adress has changed because the ip for d.nebula.zyxel.com is not the same like 52.210 an so on.
    What are the ip and hostnames for zyxel nebula cloud today?
    cheers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,631 image  Zyxel Employee
    Hi @arthurdent,
    Yes, the IP address of d.nebula.zyxel.com has been changed. You can use "nslookup" to find the current IP address. In addition, if you want to set the firewall rule, try using the domain name as an easier way.
    Zyxel Melen
  • arthurdent
    edited March 2024
    Thanks for the quick reply! :) I guess using the domain name should be better because for sure youre using some kind of load balancer, right?
    but some firewalls could not use domain names for rules… is there a way to get "all" possible ip adresses?
    cheers
  • Zyxel_Melen
    Hi @arthurdent,
    You are correct. For the firewalls that cannot use domain name for rules, I think the only way is that using NSlookup to find the all IP address.
    Zyxel Melen
Nebula Tips & Tricks
