Nebula Cloud - Authentication - SSO with Azure AD (AAD) or SAML
MartinCZ
MartinCZ Posts: 5
edited July 2 in Nebula Ideas
It would be really great and overall administration management simplified if Nebula Cloud would be capable to use SSO integration with Azure AD (AAD).
Or at least supporting SAML.
Kind of vote for AAD SSO to make life significantly easier :-)
17 votes
Active · Last Updated
«1
  • Zyxel_Melen
    Zyxel_Melen Posts: 2,567  Zyxel Employee
    Hi @MartinCZ,
    Thanks for sharing your idea.
    I will PM you to ask some detail information for investigation.
    Please help to check your mailbox.
    Zyxel Melen
  • Gilesabc
    Gilesabc Posts: 1
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Network Administrator - Switch
    +1 for this
  • Is this now considered/possible?
    Regards,
    icsaucoapsa
  • Zyxel_Melen
    Hi @icsaucoapsa,
    Thank you for reaching out to us and expressing your interest in this idea.
    Currently, this idea is under comprehensive evaluation by our technical and product development teams.
    We understand your eagerness for an update and appreciate your patience in this matter. Rest assured, as soon as there is any new information, we will promptly update you.
    Should you have any further queries or require additional assistance in the meantime, please do not hesitate to get in touch with us.
    Zyxel Melen
  • Nebula_CH
    Nebula_CH Posts: 2  Freshman Member
    Hi Melen
    are there some news about this case
    best regards
  • Zyxel_Melen
    Hi @Nebula_CH,
    Since we have some similar requests but different scenarios, could I confirm your appliance first? Is it the same as the post owner, SSO with Azure AD, or SAML when logging in to Nebula? Log in to the Captive portal? Or log in to wifi with WPA2/3 enterprise?
    Zyxel Melen
  • wifi_12344
    wifi_12344 Posts: 1  Freshman Member
    This would be great
  • DomienG
    DomienG Posts: 4  Freshman Member
    Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Security
    +1 for this
  • EntProFin
    EntProFin Posts: 4
    +1, this is pretty much standard these days.
  • Papa_DIOP
    Papa_DIOP Posts: 17  Freshman Member
    First Comment Sixth Anniversary
    SAML Integration would be awesome !…
Nebula Tips & Tricks
