Small HomeLab network system
Bunduks
Bunduks Posts: 1
Hello!
I have an idea to use these devices for my HomeLab and manage it through NebulaFLex.
I already have MikroTik Chateau LTE router.
Switch GS1915-24EP - 1.pcs
+ Access point NWA50AX - 3.pcs
+ other RJ45 connections - 8pcs.
and some time later 6 security cameras might be added but for that my idea is to use separate PoE switch and NVR for that.
Do you have some other ideas for Zyxel switch/router setup?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,220 image  Zyxel Employee
    Hi @Bunduks,
    That sounds good. Just a reminder that the PoE power budget of GS1915-24EP is 130W. Since NWA50AX will cost 16W(maximum), purchasing another PoE switch for the security cameras is correct. Connecting all PDs to GS1915-24EP might reach the maximum power budget and make the device lose power.
    Zyxel Melen
