connected to modem wifi but no internet connection
hellobee
So I have a vdsl2 p880 2t2r modem which works fine with a wired PPPoE connection. However, it looks like it also supports wireless WLAN, but although I can access the modem and activate wifi and connect to it successfully, I still can't get any connected device to reach the internet.
So I'm wondering what settings I should check -- and even if this p880 unit supports wifi internet access or if the wifi is only to access the unit itself (which seems unlikely because there are options on the modem setup pages that seem to apply only to setting up a wifi internet access point.)
Is there a manual for this p880 unit?
It is recommended that you contact your ISP for assistance.
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
