NAT-T with IKEv2 IPSEC
jmax
jmax Posts: 1 image  Freshman Member
Second Anniversary
I have a USG60W and trying to configure an IPSEC tunnel that requires NAT Traversal. I do not see this option on the screen to configure IPSEC. This option is available when using IKEv1. Is NAT-T possible to configure when using IKEv2 on a USG60W?
    PeterUK Posts: 4,446 image  Guru Member
    edited March 2024
    I think its just part of IKEv2 to do NAT Traversal in order for it to works if both ends source port must be fixed by a CGNAT if both ends are behind CGNAT and can't allow incoming.
    So it be like this
    USG60W <> ISP CGNAT <--> ISP CGNAT <> other USG
    The here it the way NAT Traversal works both 500 and 4500 both ends nailed up
    USG60W 10.0.0.2:4500 > 3.3.3.1:4500 > CGNAT 2.2.2.1:4500 > 3.3.3.1:4500 CGNAT 3.3.3.1 > 10.10.10.3:4500 other USG
    which the othe USG does the same
    other USG 10.10.10.3:4500 > 2.2.2.1:4500 > CGNAT 3.3.3.1:4500 > 2.2.2.1:4500 CGNAT 2.2.2.1 > 10.0.0.2:4500 USG60W
    Then it Traversal
    But if one end allows incoming you just need the other to be nailed up
