zyxel gs1920-24
I have an question about nebula with my gs1920-24 switch.
I have this switch connected with nebula. (green led cloud active). for example i can activate the locator led from nebula. But i mis much information, like: port status. i can not see if an port is active or not. all ports are grey. I also cannot see the local ip adresses in nebula. But changing from dhcp to static ip, is functioning. I allready did the following:
reboot switch.
installed an firmware update.
pushed the reset button, and after it the restore button.
non of these solved the problem.
who can help me?
yours dennis
Hi @dpjg,
Could you help to enable Zyxel support for me to check?
Please check the FAQ below to enable Zyxel support request.Zyxel Melen0 -
sorry for the late reply, its cloud saving mode .
after disabling it, it worked again.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
