ATP200 - unable to update antimalware
After updating "Firmware Version
V5.37(ABFW.2) / 2024-01-20 05:47:51" I have:
Anti-Malware signatures are updated to the latest version 2.1.1.20231130.0.. (success) at Mon Mar 11 09:03:50 2024
Threat Intelligence Machine Learning (TIML) signatures are updated to the latest version 1.0.0.20240310.0.. (success) at Mon Mar 11 09:03:50 2024
Refreshing services or restarting the firewall doesn't solve the problem
Could you describe the problem in more detail? The problem seems unclear to me. What is the expected result? I do not see a description of any error message.
Anti-Malware signatures - latest version 2.1.1.20231130.0
I have other ATP200 with Firmware 5.37 p2 which have Anti-Malware Signature 2.1.1.20240304.0
Very well, so this is about quite outdated Anti-Malware signatures from November 2023, while at the same time you have got another ATP200 successfully updated to new signatures (March 2024).
And as you said, neither reboot nor refreshing services makes any difference. By the way, does this include manual request for updates, if that is available in the GUI menus? Also no change?
This's the result of manual update
Thank you for the extra information. Looks like useful info.
I admit that I personally do not know where to look for the cause of the problem now, and I do not have more to suggest than to back up the device config files and reset the whole device to factory defaults, maybe even reinstall the firmware or downgrade and then upgrade again. But that would be too much of a general approach like a beginner support agent.
Therefore I will defer to and suggest that this issue should be looked into by a real Zyxel Team member in the hope that there still are some pinpoint things to check or look for to resolve the issue.
Best of luck.
We have addressed this issue. And we are trying to fix this issue.
Once there is further conclusion, we will update to you again.1 -
The issue has been resolved on the server side. Please update your signature to verify the fix.
We're seeing this exact same issue on our ATP200. All the other signature updates complete and are recent/current. But the Anti-malware will not update. We've rebooted, tried manual updates - no luck:
How do we get it to ull the latest file?
Hi @itxnc,
Could you reference this FAQ to allow our engineer to remote access your ATP200 to check this issue?
How to allow HTTPS Web GUI Access from WAN? (USG/USG FLEX/ATP/VPN) — Zyxel Community
Please send me a private message after you configure it.
Zyxel Melen0 -
Not sure what happened, but after a couple days - it finally updated. We had tried at least a dozen times. Weird.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
