How to enable SNMP AP nwa50ax
write4nik
write4nik Posts: 2 image  Freshman Member
edited May 2024 in Nebula
I have already did it in nebula cloud, my ap were updated, but I can't use snmp
Then i try to look via cli:
Router(config)# show snmp status
active : no
port : 161
version : v2c
contact : support@zyxel.com.tw
get community : public
set community : public
trap : yes
informs : yes
trap host : none
trap community: public
wireless trap : no
I've tied comand snmp-server ebable, but nothing changed
Checked manual once again, but where no other commands
How to eneble snmp?
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hi @write4nik
    At this time, the NWA50AX does not support SNMP functionality, as this model is designed primarily for home and small business environments.
    However, we recognize the importance of such features for certain users and are keen to understand your requirements better, could you share more about your specific use case for SNMP on the NWA50AX?
    Nami
  • write4nik
    That's very unusial than your decided snmp is an enterprise feature
    That's quite old function and all other devices other vendors has it by default, even 20$ devices(nwa50 $100+)
    "your specific use case for SNMP on the NWA50AX? "
    -That's not specific. Typical monitoring process, that's not an enterprise function like guest portal or radius etc.. why did you block monitoring function to my devices?
  • TomasHujcakZILLION
    TomasHujcakZILLION Posts: 2 image  Freshman Member
    Hello, we have many of this devices in the field and we need SNMP for monitoring. Can You add this functionality to GUI or CLI? When I check it, that setting are here but not configurable. Thank You
  • Zyxel_Nami
    Hi @write4nik and @TomasHujcakZILLION
    Acknowledging the interest in adding SNMP functionality to the NWA50AX, I would like to initiate a post in the WLAN Idea section for further evaluation and consideration.
    You can view and contribute to this idea in the following post:
    Nami
  • MassimilianoDelta
    MassimilianoDelta Posts: 26 image  Freshman Member
    i would liket to have snmp monitoring.
    i don't understend why there is not snmp protocol
    thanks Max
  • Zyxel_Nami
    edited May 2024
    Hi Max @MassimilianoDelta,
    Please follow this Idea post and give it a vote if you'd like to see SNMP support added to the NWA50AX:
    Best regards,
    Nami
    Nami
Nebula Tips & Tricks
