USG210 - Port Forwarding
Alex73
Alex73 Posts: 3 image  Freshman Member
edited April 2021 in Security
i should configure the firewall so that from the outside you can reach a website configured on a server in my office. I followed this document https://support.zyxel.eu/hc/en-us/articles/360001390934-NAT-Rule-Configuration-on-a-USG-Port-Forwarding- but it does not work. Do you have any advice to give me? My firwmare is version 4.32 (AAPI.0)
  • jonatan
    jonatan Posts: 200 image  Master Member
    5 Answers First Comment Friend Collector Eighth Anniversary
    Hi, when you open the website, an error message is displayed, or the home page of USG210 ? Disabled firewall on USG210 tried to go to the website?
  • Alex73
    thanks for the support,
    the error message is:
    Unable to reach the site www.yyyy.it took too long to respond.
    Search for yyyy.it with Google
    ERR_CONNECTION_TIMED_OUT
    The firewall is disabled.
    thanks
  • jonatan
    Is the website located on your local network ?
  • Alex73
    Hi, I solved the problem... the port mapping configuration on the tester's router was incorrect. It was configured to forward all traffic to the ip address of the old firewall ....
