USG210 - Port Forwarding
i should configure the firewall so that from the outside you can reach a website configured on a server in my office. I followed this document https://support.zyxel.eu/hc/en-us/articles/360001390934-NAT-Rule-Configuration-on-a-USG-Port-Forwarding- but it does not work. Do you have any advice to give me? My firwmare is version 4.32 (AAPI.0)
Hi, when you open the website, an error message is displayed, or the home page of USG210 ? Disabled firewall on USG210 tried to go to the website?
Hi, thanks for the support, the error message is: Unable to reach the site www.yyyy.it took too long to respond. Search for yyyy.it with Google ERR_CONNECTION_TIMED_OUT The firewall is disabled. thanks
Is the website located on your local network ?
Hi, I solved the problem... the port mapping configuration on the tester's router was incorrect. It was configured to forward all traffic to the ip address of the old firewall ....0
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
