It is possible to restore the NWA5123-AC-HD device
ZyxelAp
ZyxelAp Posts: 5
edited May 2024 in Wireless
Hello
After an unsuccessful device reset. Is it possible to restore the equipment? I am attaching the log file.
when entering commands it gives an error
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,716  Zyxel Employee
    Hi @ZyxelAp
    Couldn't your AP boot up? Did you do a firmware upgrade but a power outage occurred during the upgrade process?
    Zyxel Melen
  • ZyxelAp
    ZyxelAp Posts: 5
    Dear Melene! Thank you very much for your help
    Everything is restored and working
  • Zyxel_Melen
    Hi @ZyxelAp
    Zyxel Melen
  • ZyxelAp
    ZyxelAp Posts: 5
    Dear Melen, out of ignorance, I did not disable it on the NXC2500 controller, auto-updating of points to version 6.10 was enabled, this point caught this update and after the automatic installation this incident occurred. Found an article https://community.zyxel.com/en/discussion/12858/problem-with-ap-nwa5123-ac-hd
    the situation is similar, but my point does not respond to commands..
  • Zyxel_Melen
    Hi @ZyxelAp
    The command you typed in is not for our AP. Let me send you a document for firmware recovery. Please check your inbox.
    Zyxel Melen
  • ZyxelAp
    ZyxelAp Posts: 5
