Nebula Traffic shapping new option
PhCANDIDO
PhCANDIDO Posts: 1 image  Freshman Member
Ideas master
edited April 2021 in Nebula
It's possible to add new option to the parameter "WAN load balancing algorithm".
Actually only "Round Robin" and "Least load first" are enable. The option "Wan1 active/ Wan 2 Backup" will be a very good option.
  • Zyxel_Barney
    Zyxel_Barney Posts: 85 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    Hello @PhCANDIDO
    A third WAN load balancing algorithm called "failover" will be available in the next Nebula update on December 17.
    Failover makes use of the active/backup (or active/passive) WAN interface that you just described.
  • Nebula_Bayardo
    Nebula_Bayardo Posts: 179 image  Zyxel Employee
    Hi @PhCANDIDO
    As Barney said, the Failover option is now available on NCC since December 17.
    Check it out if you haven't :smiley:
Nebula Tips & Tricks
