can i connect to VPN for EX3301-T0
can i connect to VPN for EX3301-T0, if so how to connect ?
I think the device has no integrated VPN …
Hello @pavankpoth
Welcome to the forum.
@Peter2 is correct that the EX3301-T0 does not have any VPN client or server built into it.
However, it can do IPSEC pass through, so you could run a VPN that uses IPSEC through it, see below from https://www.zyxel.com/uk/en-gb/products/dsl-cpe/dual-band-wireless-ax1800-gigabit-ethernet-iad-ex3301-t0/specifications
You could probably also run an SSL VPN through it as well, because an SSL VPN client would use HTTPS to connect.
The user guide for EX3301-T0 is at https://download.zyxel.com/EX3301-T0/user_guide/EX3301-T0_V5.15_5.70_Ed2.pdf linked from https://www.zyxel.com/uk/en-gb/support/download?model=ex3301-t0
Kind regards,
Tony
Hi Tony,
I'm trying to use my Zyxel EX3301-T0 as a VPN client to connect a camera to a NAS located 4kms away through VPN and I've found this post. I'm not really that literate on network, could you tell me some keywords or any kind of indication on how to start doing an IPSEC pass through? I have a VPN Server created on my NAS that lets me create an OpenVPN server, a PPTP VPN Server and a L2TP/IPSec VPN server. Is there a guide or something that could help me use my Zyxel EX3301-T0 as a VPN client so I can connect the camera without forwarding the ports?
Thank you very much in advance!
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
