Config of DECT-Base Gigaset C160IP at DX3301-TO
Hello everybody
I need some helb to make the Configuration of DECT-Basestation Gigaset C160IP at the Zyxel DX3301-TO
Hello @chrislink
Welcome to the forum.
I cannot find the manual for a Gigaset C160IP DECT phone, but it might be similar to the C470 IP which has a setup manual at https://gse.gigaset.com/fileadmin/legacy-assets/A31008-M1916-S301-2-9U43_en_RUS.pdf
* Might your phone be a Gigaset C610IP device? see https://gse.gigaset.com/fileadmin/legacy-assets/A31008-M2312-A601-1-UZ19_en_AE.pdf
If similar to a C470 IP, then you need to plug the DECT phone base unit into power and into one of the Ethernet LAN ports of the DX3301-T0 and then do the VoIP configuration in the Gigaset phone itself.
* You will need to have a VoIP SIP provider set up in advance, so that you can put details of your VoIP SIP account into your Gigaset phone's configuration settings.
Kind regards,
Tony
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 496 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
