NR5101 Routing
Hi, im using my NR5101 as Access Point. It has a static IP Adress und DHCP is set to relay. I also want to use its 5G and set it up as Failover.
Config:
NR5101: 192.168.88.3; ROUTER: 192.168.88.1
I created a simple test with 1.1.1.1 as DEST and the NR5101 as Gateway. It does not work. Packages are dropped.
Question: What do I miss? Any config I have to to at the NR5101? It has 5G connection of course.
Hi @Tobi82 ,
You can refer to this FAQ to know how to configure a Failover:
Could you share the purpose of this test? It seems unusual to configure your MikroTik router with the NR5101 IP address as the gateway for 1.1.1.1
Zyxel_Judy
- 441 Beta Program
- 534 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
