Rover doesn't work!
Papou
in Home Router
When I setup 7510 as an access point Rover App doesn't find the rooter!
When I go back to router mode by the web GUI, Rover works fine.
I use Version 1.1.0.240201.
Is there a newer Version of Rover?
Hi @Papou
In router mode, simply connecting to the device's SSID allows you to find the device.
However, if the device is in bridge mode, the app cannot find the device because the app is not supported in bridge mode scenarios0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
