Console port
hello quel câble faut-il utiliser pour les AP Zyxel ?
je viens de remplacer mon AP wifi 6 par le nouveau AP wifi 7 et je me suis rendu compte en installant qu’il y avait un port console.
il sert bien à configurer AP en cas de problème ?
C’est bien un câble bus , USB TTL ?
Merci
hello which cable should be used for Zyxel APs? I just replaced my AP wifi 6 with the new AP wifi 7 and I realized when installing that there was a console port. Is it useful to configure the AP in the event of a problem? Is it a bus cable, USB TTL? THANKS
Hi @Phalco75,
The console port is used to recover the firmware if firmware upgrading fails.
You may find detailed information about the console cable in this FAQ.
Zyxel Melen0
Hi @Phalco75,
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
