Does AX5400 "require" antennas?
RobH2
RobH2 Posts: 2
edited May 2024 in Wireless
We purchased an AX5400. All ads and photos show it without antennas, yet, antennas are listed as available. The documentation does not specifically say if they are "required" or not. We previously had a WAC6550 and while it could accept antennas, they weren't required and its range was adequate.
So, does the AX5400 have any kind of range "without" antennas?
Best Answers
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279  Zyxel Employee
    Hi @RobH2
    Could you please confirm if the AX5400 access point you mentioned refers to the outdoor AP WAX655E? The outdoor AP WAX655E is not embedded with internal antennas, and external antennas are available for separate purchase.
    Currently, we only have the 802.11ac outdoor AP, WAC6552D-S, which supports internal antennas. For the AX5400 or higher version, the outdoor AP with embedded internal antennas is still under planning.
    Kay
  • Zyxel_Kay
    Hi @RobH2
    Thank you for the suggestions for improvement. We will escalate your concerns to the responsible team.
    Kay
  • Zyxel_Kay
    Hi @RobH2
    Kay
  • RobH2
    RobH2 Posts: 2
    Thank you. We'll order antennas. You should update your documentation to state that there are "no" imbedded antennas. Currently, no source states that clearly. All photos on the web show the unit without antennas which implies that it doesn't need them.
    Regards,
    Rob
  • Zyxel_Kay
    Hi @RobH2
    Kay
