[NEBULA] Network Servers - add more DNS names with same IP
We have in our network own mail server and WEB server. It is same server with one IP address. I want to add tho DNS names web.xxx.yy and mail.xxx.yy pointing tto o same IP address. It is not possible. When I try, only one DNS name is possible, when adding second entry, than the field is red and I cannot save.
Hi @Ludek
NCC has just been updated.
You should now be able to create DNS address records with the same IP address.
Regards,
Barney5
Hello @Ludek
Instead of creating multiple FQDN, I would recommend using wildcards (*) to denote your domain name.
Example:
Cheers,
Barney0 -
I know I can use *, but the problem is that www.xxx.yy is pointing to another address to web hosting ...
I need 3 addresses - www.xxx.yy (IP outside), zakazky.xxx.yy, mail.xxx.yy (internal server)0 -
Hi @Ludek
You are right. Wildcards won't help in your current setup.
I will inform our team whether it is possible to improve the DNS Address Record settings.
Regards,
Barney1 -
Thank you very much :-)
Ludek.0 -
Hi @Ludek
Regards,
Barney5 -
That's great. Many thanks
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
