How to configure 6in4 tunnel with Hurricane Electirc on USG 50?
I have a very old product - USG50 and would like to configure the 6in4 tunnel over PPPoE, but never got it successfully.
I read the article below, but my LAN client still can't get the IPv6 address and HE tunnel seems not working. Can someone teach me how to make it successfully?
he:
Tunnel:
LAN:
Static route:
your prefix length should be 64 ?
Yes, with prefix 64, I can receive the IPv6 address, but I have some devices connected to a router that is under USG50, I want those devices to have the IPv6 address also, but I am not sure what the steps are.
I mean set prefix 64 at RA filed
Devices are under USG50 might have ipv6 address.
Yes, I did that and received IPv6 address.
And another router's WAN has IPv6 address.
But router's LAN and device under the router didn't have the IPv6 address
It sounds like your are talking about the LAN of the third party router under the USG.
I thought you have to allow RA traffic on Router. Maybe you can try to capture traffic on Router's LAN to see if any ICMPv6 .
Prefix /64,
PC under USG:
PC under another router can't receive RA packets, but if the router connects to another IPv6 environment (not USG), the router can send the RA packets without making any changes.
I don't know if there is any configuration I need to change on USG for prefix /48?
Hi @ftiraid ,
Greeting Forum, Please kindly find index. We need further information.
on the other hands, USG50 is too old, For security issue and support,
We recommend you replace to the new FLEX/ATP
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
