LTE3316-M604
DWARD
I have the above device and prior to purchase I looked at documentation so I could use it over a VPN, it appeared I could, however when the device comes I can't see any VPN options. Please can you advise if I can use a VPN with this device. Thank You
You can use VPN by using LTE3316's connectivity.
LTE3316 only provide the ability to get online and you need to find the VPN provider to purchase VPN service.
See also
Thanks for supports.
-1
- 238 Nebula Ideas
- 6.8K Security
- 754 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
