GS1920-48 default login details
ant_thomas
in Switch
Hi
I've bought a GS1920-48 (v1 not the newer v2)
Can't seem to login using admin/1234
I've used the factory reset button a few times but the default login details don't work.
Any ideas of how to reset another way or login?
The switch comes up fine on 192.168.1.1 - it is pingable and the webui asks for login details.
Hi @ant_thomas,
I want to clarify some questions with you:
- Did you press the reset button for more than 5 seconds?
- After pressing the reset button, did the link LEDs light up?
- What happened after you used admin/1234 to access the switch?
- Did you allow these functions on your browser?
- Did you use SSH to login with the same local credential, but login failed?
Zyxel Melen0 -
- Yes
- Yes
- The login credentials popup in the browser kept reappearing. If I pressed cancel it would then give a login error.
- I haven't checked this. I will later today.
- SSH port seems to be shut, it didn't give any login prompt.
Hi @ant_thomas,
Thanks for the update. Could you help to do one more test?
- Use Zon Utility to find your switch and try to change switch IP address with default password.
Zyxel Melen0 -
Hello
Using Firefox instead of Chrome has fixed the problem.
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
