SIM card stuck
JukkaS
I removed sim card "accidentally", pushed it back but am not able to remove it again. Seems like the card is stuck somehow. Any tips?
It is Zyxel LT7460
Hi JukkaS , does the sim card unable be detected on LTE7460? If the sim card network service is working as normal, it's not recommend un-plug the stuck sim card forcibly, to avoid the pin foot break off that can't plug and unable detect sim card anymore. If the network service has some issue there, you can contact to your service provider for help.
I broke the SIM card port of the router model 5101
-1
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
