Visual indicator for manually disabled ports
Sometimes I need to disable a port for troubleshooting, and it is very easy to forget about it. It would be great if Nebula gave a visual indicator or icon for ports that are disabled. Something simple to add the legend like a little red X.
Agreed, I find this an annoyance on a regular occasion. An additional symbol to display what ports have been manually disabled from the device summary window would be an excellent addition.
Hi users,
Thank you for your suggestion. We believe this feature could benefit our users, and we will consider it carefully. Please stay updated with the Nebula News and Release Notes for upcoming enhancements.
In the meantime, you can go to Configure > Switch > Switch ports in the Nebula interface and check the Enable column as a recommended workaround.Zyxel_Judy
- 603 USG FLEX H Series
- 481 News and Release
