Incompatibility XS1930-10 switch and EX5601-T1 Router
I have 2 Zyxel products, both support higher than 1Gbps networking.
EX5601-T1 Router (1G/2.5G)
XS1930-10 switch (1G/2.5G/5G/10G)
After connecting, link speed remains at 1G networking speed.
I have tried:
- Check latest update on EX5601-T1 Router. It's V5.70(ACEA.0)T56C_b8_1108
- Updating to latest Firmware Running V4.80(ABQE.3) | 10/06/2023
- Forcing 2.5Gb on the port in XS1930-10. This results in a disconnected DOWN state.
- Running a 15 meter CAT 6A cable (shielded) directly between both. This is a known Cable to work with 10G. Link Stays at 1G, DOWN state when forcing 2.5G
- Tried another port, same result, DOWN state when selecting 2.5G
- 10G works fine with server and clients
- 5G works with 1 client (QNAP USB3 5G)
- 100Mb and 1Gb connections to other devices don't have any issues.
What can I do to remedy this?
Hi @Ztegeman,
Could you help to use this known cable to connect a loop on the XS1930-10? I want to check if the XS1930-10 can link up in 2.5G using this known cable.
Zyxel Melen1 -
Hi @Ztegeman,
If the cable is able to link up in 2.5G, please consider contacting your ISP to upgrade your EX5601-T1. I have used EX5601-T1 with the latest firmware to connect to XS1930-10, which links up in 2.5G. So, this could be a firmware issue. The running firmware of your EX5601-T1 is a date code firmware that might not been fully tested.
Zyxel Melen0 -
Thank you Melen,
Unfortunately, the switch does not allow a loop. If I connect a loop, the lights will stay off and I have to restart the switch for the ports to work. However I can "throttle" a link down to 2.5G.0 -
Hi @Ztegeman,
Thanks for your update. Please contact your ISP to upgrade the firmware for EX5601-T1 and try again.
Zyxel Melen0 -
Thank you Melen,
I have contacted my ISP, and I got a newer version. But they pointed out that only the WAN and first LAN first port are 2.5GbE. I retraced the cables going to the router and I didn't use the correct/faster port. I connected the uplink form the switch to the first LAN port, forced 2.5GbE and now I have a cyan light (2.5Gbps speed).
In hindsight I should have read the specs more carefully from the router.Thanks!
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
