Zyxel ATP500 L2TP VPN connection unavailable
bav
bav Posts: 20  Freshman Member
edited April 2024 in Security
Hello!
I am trying to setup L2TPIPSEC VPN client to site. I added VPN gate and added VPN Conection with UNchecked "Enabled mode config"
Anyway I do not see available VPN connection in L2TP VPN page in VPN Connection: None
Whats wrong? Enabled mode config is desabled
thx
    PeterUK Posts: 3,910  Guru Member
    you need to set Encapsulation to transport
«13
    You need to use IKEv1
  • bav
    ikev1 is already in place
    Have you setup VPN connection with that IKEv1 that rule should show up in L2TP settings
  • bav
    sorry, what do you mean?
    You have setup IKEv1 in VPN gateway now you need to add that rule in VPN connection then in L2TP VPN it will show up
  • bav
    edited April 2024
    Thanks for reply!
    Could you please explain how to add that rule in VPN connection?
    like so
  • bav
    I already had these settings:
    1. VPN gateway created and added to int Ge2
    2. VPN Connection created (VPN Gateway assingned)
    3. Result is the same(no VPN connection available)
  • bav
    edited April 2024
    Thanks so much! It appears now!
    Now I am trying to get configuration from server for Zyxel SecurExtender VPN client and get error - Server is not found, check server IP/port.
    I checked IP and port(443) and they are ok
    Policy control has rule WAN-to-Device
    What might be the issue?
    Auth: Username + password
    User is allowed
