Zyxel ATP500 L2TP VPN connection unavailable
Hello!
I am trying to setup L2TPIPSEC VPN client to site. I added VPN gate and added VPN Conection with UNchecked "Enabled mode config"
Anyway I do not see available VPN connection in L2TP VPN page in VPN Connection: None
Whats wrong? Enabled mode config is desabled
thx
you need to set Encapsulation to transport
You need to use IKEv1
ikev1 is already in place
Have you setup VPN connection with that IKEv1 that rule should show up in L2TP settings
sorry, what do you mean?
You have setup IKEv1 in VPN gateway now you need to add that rule in VPN connection then in L2TP VPN it will show up
Thanks for reply!
Could you please explain how to add that rule in VPN connection?
like so
I already had these settings:
- VPN gateway created and added to int Ge2
2. VPN Connection created (VPN Gateway assingned)
3. Result is the same(no VPN connection available)
Thanks so much! It appears now!
Now I am trying to get configuration from server for Zyxel SecurExtender VPN client and get error - Server is not found, check server IP/port.
I checked IP and port(443) and they are ok
Policy control has rule WAN-to-Device
What might be the issue?
Auth: Username + password
User is allowed
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 431 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
