How to activate SecuExtender VPN
hara
hara Posts: 2
I'm having trouble activating the VPN, It says error code: 70. Upon checking it has a problem with administrative rights on the computer. I checked, and my computer is already an administrator. I'm not the one who bought the VPN and my client sent me a link to install it. Kindly please help me. Thank you
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,203  Zyxel Employee
    Hi @TeleCrew
    Failed activation may be caused by the VPN client that cannot access the licensing server to get authorize licensing token. The licensing server FQDN is tgbosa.com
    Please confirm if your network allows outgoing connection to the licensing server.
    Kay
    See how you've made an impact in Zyxel Community this year! https://bit.ly/Your2024Moments_Community
Security Highlight
