Multi VLAN configuration on single port XMG1915-10EP
DavaD
DavaD Posts: 1
Hello everyone, I own an XMG1915-10EP switch and an NWA50AX access point. In my AP, I have configured 2 SSIDs, one for LAN with VLAN ID 10 and one for GUEST with VLAN ID 30. In the switch, I have connected the access point to port 1, and in port 2, I have connected my opnsense firewall in which I have configured VLAN 10 and 30 with their respective DHCP. I would like to understand how to configure the switch to make these VLANs 10 and 30 visible only to ports 1 and 2. Additionally, I would like to understand how to configure the management VLAN ID of the access point to make it accessible, by default is ID 1. Thank you.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,321 image  Zyxel Employee
    Hi @DavaD ,
    Based on your description, I understand that your network topology is as follows.
    To meet your requirements, please navigate to the local GUI of the XMG1915-10EP, then go to Switching > VLAN > VLAN setup, and configure as indicated below. After making the changes, click 'Apply'.
    By default, the management VLAN ID for the access point is set to ID 1 is done.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @DavaD ,
    Zyxel_Judy
    Untitled Image
