SYS led flashing
Hi @Zyxel_Jeff
I have already downloaded the firmware, but the problem is that I can't do anything in the console, it doesn't accept any commands.
As soon as I connect to the console with putty (RS232 cable), it just shows a message repeating endlessly at a regular interval:
FLASH: AMD 16MFLASH: AMD 16M
FLASH: AMD 16M
FLASH: AMD 16M
In this situation I can neither reset nor load the firmware.
I don't know if there is a command to unblock this situation and then allow me to restore the firmware.
@Zyxel_Jeff : Thank you for the firmware link and the suggestions. It looks like @studio has great difficulty in trying to end the continuous stream of console warning messages (FLASH: AMD 16M). If there is a known method to stop the console messaging, I think that would be the most helpful step for @studio to be able to continue the process of reset/recovery/firmware reload or upgrade.
Hi @smb_corp_user OK, thank you.
Hi @studio Could you press the reset button for around 5 seconds and then release it to try resetting the Zywall USG 100? This action could be helpful for you. Once you have successfully reset the Zywall USG 100, please check if the device is functioning normally or not. Thanks.
I have already tried several times to do the reset procedure indicated in the user manual (hold down the reset button with a paper clip) but nothing happens, the continuous flow of warning messages from the console is always the same:
FLASH: AMD 16M0 -
Hi @studio
Regarding the console message "FLASH: AMD 16M," there are two possible reasons why this log message might appear:
(1). The power adaptor's voltage may not be stable. Please check if the power adaptor is functioning normally. Perhaps, you can use another appropriate adaptor to verify it.
(2). If the firewall has a hardware issue, it may also show this message. If so, we recommend considering an upgrade to Zyxel's new firewall product.
Thanks.
Very good points. I should have known that the power adapter could have an issue separately from the Zyxel device itself. Quite possible scenario based on the event of the area power failure.
Then again, there is also the potential for device hardware failure issue, just like you said.
OK, thank you for your comment😀.
Thank you very much for the suggestion nr.1.
I have replaced the power supply, and the device works well.
However, I’m taking the opportunity to upgrade, and I’ve already purchased a new Zyxel firewall that will arrive soon.
Thanks again
Hello @studio
OK, no problem. Many thanks for your update and feedback. Thank you for purchasing the Zyxel firewall product. If you have any questions in the future, please let us know😊.
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 917 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 915 Nebula FAQ
- 422 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
