How do I "fix" the message "invalid preshared key"?
Swampy
Swampy Posts: 3
edited April 2024 in Home Router
Trying to set up the guest account - each time I select "save" i get a message stating "invalid pre-shared key". What am I missing/need to do? (Please - in VERY basic simple steps !!!)
  • Zyxel_Kay
    Hi @Swampy
    To provide you with the most accurate assistance, could you please share with us which model of access point you are using? Additionally, are you looking to set up a guest SSID?
    Kay
  • Swampy
    Swampy Posts: 3
    so I have the modem/router detailed in the first photo.
    the second photo shows the _guest account “entry point”.
    Third photo is the resultant screen.
    Fourth photo is the message I get after selecting save (happens if I change the password or leave it as the default provided)
  • Liba
    Liba Posts: 205 image  Master Member
    First Comment First Answer Second Anniversary
    Maybe you can change the password to a number or text.
    Or try to obtain the latest firmware from your ISP or retailer.
  • tonygibbs16
    tonygibbs16 Posts: 977 image  Guru Member
    Hello @Swampy
    If you want, there is some later firmware for VMG1312-T20B at https://support.zyxel.eu/hc/en-us/articles/4403361365778-Zyxel-CPE-Devices-Firmware-Advanced-Downloads-Firmwares-and-other-resources which could take you to V5.30(ABSB.5)C0 .
    Kind regards,
    Tony
  • Swampy
    Swampy Posts: 3
    Downloaded and installed the latest firmware - still coming back with "Invalid pre-shared key"
  • tonygibbs16
    edited April 2024
    Hello @Swampy
    Ok.
    Apparently under Network Setting > Wireless > Guest/More AP > Edit you can generate a network password automatically, which might help you.
    It should I hope generate a valid password as a valid pre-shared key.
    * see screenshots below.
    The device is probably also being particular about what characters are in the key, so automatic generation should help with this too.
    Kind regards Tony
